Possible Leaking Wax Seal - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2008, 01:57 PM   #1
I recently installed a new tile floor, when placing toilet in place, I used two wax gaskets, 1 normal, 1 thick with horn, toilet sealed great....absolutely no leaks, however when I flush toilet it sounds like dripping...will you hear water drip for a few seconds after flush ...into waste pipe...or is this an indication that that its leaking???.... I cant see underneath...its a raised basement bathroom thats enclosed...so I cant see underneath....I mean its no big deal to try and reset toilet until I get it I just wonder if this dripping sound is standard???
mcconnre is offline   Reply With Quote
Old 11-29-2008, 02:17 PM   #2
maybe adjust the overflow valve in the tank maybe that's the sound
chad4290 is offline   Reply With Quote
Old 11-29-2008, 02:39 PM   #3
I agree that I would be listening and looking at the tank for drips before replacing the wax seal(s). Should you decide to pull the toilet again, take the time (and a few bucks) to buy a flange extender so you do not need two seals. Too many things can happen when using more than one seal. If one slides while installing, it can block the drain hole.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
seal a polished marble bathroom floor? tarheelblue Flooring 21 01-12-2012 11:58 AM
To seal or not to seal........ luce Flooring 1 05-18-2008 07:00 AM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-02-2008 11:00 PM
Stink'n mice -- garage door seal... RippySkippy General DIY Discussions 6 03-03-2008 03:11 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
