Old 03-20-2007, 09:37 AM   #1
possible leak after water meter
I had a small leak after my water meter and just after my shutoff valve. I replaced the reducer - which connects the shutoff to 3/4 copper sweat fitting w/ threaded male end. I used pipe dope and teflon tape and I have no more leak- or no dripping but around the threads between the reducer and sweat fitting there is a little moisture. Not enough to drip off but even after I wipe it off it appears a few hours later. Is this just normal condensation due to the extremely cold water ( minnesota winter) into my relatively warm basement- 60 degrees?
I hope so- any advice is greatly appreciated.
PS I re did the fittings - took apart and re tightned with new tape /pipe dope a few times with the same outcome- Am I doing something wrong?
sharp1 is offline   Reply With Quote
Old 03-20-2007, 02:04 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Sounds like condensation, not necessarily a leak, but if it persists, you can smear a little clear silicone on the threads to seal it.
If it is a leak, you should be able to easily tell it by looking at the (usually) triangular leak indicator on the meter. It spins rapidly when a faucet is running, but should be perfectly still when all water is off and there is no leak. If there is a small leak, there will be small movement of the triangle.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-20-2007, 04:45 PM   #3
Mike,
THanks very much. I'll check the arrow. I never even thought of that...
Dave
Turning valve at water meter KCnorthernCA Plumbing 15 10-23-2006 12:35 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Water heater leak? spydrtrbo Plumbing 1 06-29-2006 08:56 AM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 10:13 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 06:00 AM
