Old 07-12-2009, 10:08 PM   #1
Possible to join PVC drain pipe to old iron pipe?
Is it possible to join a section of PVC drain pipe to old iron drain pipe? I have a leak in a drain pipe, but the vent pipe above is iron and the iron pipe below the leak goes into the concrete, and I don't want to bust it out.
If that is not possible, is it feasible to join no-hub cast iron pipe to old iron drainage pipe? And if so, how firm is that no-hub joint?
darsunt is offline   Reply With Quote
Old 07-12-2009, 11:46 PM   #2
HVAC / Plumbing
Yes there are . You can find the materials at h.d. or lowe's... most of the time I use a fernco fitting
kenmac is offline   Reply With Quote
Water softener & Iron filter drain DSKUP Plumbing 3 02-17-2009 11:14 AM
Cutting Iron Drain Pipe jonathan03 Plumbing 12 01-31-2009 10:33 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 06:46 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
