Old 01-04-2012, 03:16 PM   #1
Portable shower system project
Hi all,
I'd like to install a portable shower in my office restroom.
Here is an example of what I want:
http://www.shower-anywhere.com/Offic...er-Stalls.aspx
It pulls water from the sink and drains into the toilet, which is what I want in order to avoid an expensive plumbing project.
This kit costs $800 + another $370 for the drain assembly. Do you guys think I could do it cheaper with off the shelf parts from a hardware store?
Delta223 is offline   Reply With Quote
Old 01-04-2012, 03:29 PM   #2
MarginallyQualified
It drains up hill?
I think you could (and should) do a proper tie in to the building
(water and sewer pipes) for far less.
hth
Old 01-04-2012, 04:21 PM   #3
Maybe 'drain' was the wrong word. Here is what it says"
If a floor drain is not available a kit is available AUDR-1 that automatically pumps the water into a commode, bathtub or commode when showering. When using the above kit the shower stall opening is 5.50 inches above the floor. .
I don't think I could connect a shower to the plumbing by myself. I'm not handy with home improvement at all, and I may need approval from the landlord
Prova Shower System Questions. Brian Buan Tiling, ceramics, marble 6 03-25-2011 01:36 PM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 07:43 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
new system install.....questions firedogut HVAC 4 10-04-2009 08:10 PM
