Old 02-08-2012, 10:23 PM   #1
Portable Dishwasher
Looking for feedback on plumbing a portable dishwasher direct. Is this something that can be done fairley easily or should it be done by a professional plumber.
blue collar is offline   Reply With Quote
Old 02-08-2012, 10:28 PM   #2
Portable Dishwasher
Plug it in, hang hose in sink, I think you can handle it.
Old 02-09-2012, 07:13 PM   #3
Portable Dishwasher
I take what you are talking about is removing the faucet hookup and installing it permanently under the counter. My Grandfather did this to one years ago. You will need to go underneath and remove the water inlet hose at the inlet valve and install a braded inlet hose and connect it to the water tap for your dishwasher. The drain hose is going to be easier...remove the end of the hose from the faucet hookup, and use an automotive style hose clamp to affix it to the drain pipe
av-geek is offline   Reply With Quote
Old 02-09-2012, 08:58 PM   #4
Portable Dishwasher
Thks partner that is exactly the info I was looking for.
conversion of portable dishwasher to stationary one grimsbyman Plumbing 14 02-19-2013 08:54 PM
ge portable dishwasher problem rollsy1977 Appliances 2 10-08-2010 09:07 AM
Frigidare portable dishwasher won't drain Tricia Appliances 0 11-18-2009 05:11 PM
Portable Dishwasher hookup MagsMom Plumbing 3 06-04-2009 11:09 PM
Kenmore Portable Dishwasher Won't Drain - PLEASE Help! katb1030 Appliances 8 07-10-2008 01:38 PM
