Popup Not Holding Water In Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2011, 03:57 PM   #1
m1951mm's Avatar
Popup not holding water in sink
I am working in a house where the popup's are not keeping water in the vanity sinks. The previous owners were not cleaners by any stretch. There is lime and soap built up on the stoppers. Will I run into problems if I just remove the ball joint, soak the stoppers in vinegar, clean them and reinstall???? Will I have issues with the shaped washer that fits around the ball thingie ( not sure what to call it) if I do not replace them. I tried to find new ones at Home Depot and they do not carry them. I just do not want any leaks from the popups Do I need to buy new stoppers??
Any hints that will make this process easier, I have six sinks to do, would be very much appreciated!!!!!!!!!
Mickey
m1951mm is offline   Reply With Quote
Old 08-12-2011, 07:04 PM   #2
Lime away or CLR
Master of Cold is offline   Reply With Quote
The Following User Says Thank You to Master of Cold For This Useful Post:
m1951mm (08-13-2011)
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Lack of hot water pressure in bathroom sink kc1983 Plumbing 4 05-22-2009 09:24 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
