Popup Drain, Is It Really Suppose To Be Like This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-06-2007, 12:08 AM   #1
Popup Drain, is it really suppose to be like this?
So it just so happens that my vanity and vanity top comes from Home Depot. But my faucet comes from Rona, although I originally thought plumbing parts are standardized I am not so sure anymore. When I went to install this (I kind of just placed it like that in the picture) But the lift rod only fits in a slant (almost a 60 degree angle). Now to my knowledge, I am quite sure that is suppose to be perpendicular to the faucet and vanity top and if you even tried to attach it to the rest it will force the rest of the popup drain below to be slanted. Is this normal? I was actually thinking of going to Home Depot tomorrow and pick up look at some other faucets to see if they're all like that.
iOsiris is offline   Reply With Quote
Old 08-06-2007, 01:38 AM   #2
Rewards Points: 150
I'm not sure if it's suppose to be or not, but have seen ones that go in at an angle. The ball joint that it attaches to for the stopper still seems to work the same...
slakker is offline   Reply With Quote
Old 08-06-2007, 02:00 AM   #3
Hmm well if it works the same then i guess no prob then! Well should I use plumber's putty or silicon to seal the flange into the sink? (The instructions refer to both) ?
Old 08-06-2007, 11:27 AM   #4
Rewards Points: 150
I used plumbers putty, but have been recommended to use silicon by some (not all) plumbers. I've never found a problem with putty and like the way it's easier to take apart if you need to repair anything. I also used plumbers grease on the ball joint that works the stopper.
Old 08-06-2007, 09:37 PM   #5
Journeyman Plumber
Ron The Plumber's Avatar
Yes some stoppers are in a slant as you show.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
