Popping Sound (loud) In Hot Water Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-25-2009, 01:57 PM   #1
Unhappy
Popping sound (loud) in hot water tank
I hear a loud popping sound mostly after one of the rinse cycles on my washing machine but more recently periodically I hear this sound without the machine running.
I had heard the tank needs to be cleaned from sediment. Any one know what is causing this?
andrewd80 is offline   Reply With Quote
Old 12-25-2009, 03:33 PM   #2
Rewards Points: 1,418
Just a guess. There could be a layer of sediment (like sand) at the bottom of the tank and every once in awhile a pocket of steam develops down there and makes a popping sound as it breaks through the layer of sediment and commingles with (and is absorbed into) the rest of the water.
The hotter temperature down at the bottom of the tank (gas and oil models), insulated from the rest of the water by the sediment, could result in the layer of porcelain or glass inside the tank becoming cracked, shortening the life of the tank. Thus you are advised to drain a few gallons of water twice a year to get the sediment out.
Old 12-25-2009, 06:38 PM   #3
DIY staff
Rewards Points: 7,174
Good guess,I'd say. Time to get a new heater--sorry--MIKE---
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Well Water Pressure Tank for Air? Reilley Plumbing 8 02-20-2009 01:53 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
How much would you charge to plumb a hot water tank? Piedmont Plumbing 12 08-21-2008 12:35 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
