Old 10-10-2012, 06:18 PM   #1
Popping noise in pipe
I just bought a new house and redid the bathroom. When I turn the hot water on there is a popping noise in the pipes for the first 20 seconds and then it stops. It does not do this at all with the cold water. what could be causing this? The noise sounds like an igniter trying to light something, but it is not an igniter in my heater.
Mallard1123 is offline   Reply With Quote
Old 10-10-2012, 06:24 PM   #2
Where not there to hear it it, but when calcium builds up the the bottom of a water heater it pops loose when it gets heated. It will sond like a popcorn popper if it's really bad.
A water heater needs to have a hose connect to the bottom of it about every 6 months to drain off some of the solids that build up on the bottom.
I'd bet that 99 % of home owners have never drained off the soilds since they have owned the house.
Old 10-10-2012, 06:25 PM   #3
I just installed a brand new hot water heater two weeks ago. This only does it in my bathroom.
Old 10-10-2012, 08:20 PM   #4
call me E
TheEplumber's Avatar
Sounds like pipe expansion- especially on the hot water side or the drain expanding due to hw. The pipe is rubbing on wood as it expands- just a guess
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Alan (10-18-2012), Lightfoot (10-11-2012)
Old 10-12-2012, 12:53 PM   #5
Yup, thermal expansion.
plumberinlaw is offline   Reply With Quote
Old 10-18-2012, 12:00 AM   #6
Ok thanks
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Driveway culvert to underground pipe zrooster99 Landscaping & Lawn Care 4 06-25-2011 01:42 PM
Popping noise in the flat roof mtrx Building & Construction 6 03-15-2010 11:18 PM
Popping noise engineered hardwood on concrete sony Flooring 0 02-05-2010 10:04 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
