Old 10-23-2011, 09:14 PM   #1
Pop Up Assembly Removal
I am removing a faucet along with the drain pipe assembly and could use some suggestions on how to get the drain pipe assembly out. I removed the P Trap and got the nut, seal and washer all the way down but the ring that sits on the tube in the sink will not budge. Other than a hacksaw, any suggestions? I tried oil but that did not help. I have tried to hold the ring and then twist the tube but that did not work. Thank you!
Faucetguy is offline   Reply With Quote
Old 10-23-2011, 10:08 PM   #2
Persona Non Grata
VIPlumber's Avatar
You'll need a dumbell wrench/drain removal tool . You should be able to find it at a big box.
VIPlumber is offline   Reply With Quote
Old 10-23-2011, 10:20 PM   #3
Super Moderator
How will that help with a pop-up drain ring?
oh'mike is online now   Reply With Quote
Old 10-23-2011, 10:44 PM   #4
Persona Non Grata
VIPlumber's Avatar
I think I got fixated on drain and kinda zoned out on the rest. Sorry OP but I was way off base.
Old 10-23-2011, 10:52 PM   #5
Military Mom of 4
Snav's Avatar
If it's been adhered into place your solvent depends on the type of adhesive - first try vinegar and something to scrape with to work it under the flange because most drains are set with plumber's putty which is applied underneath.
If you see the slick shine of silicone then buy a solvent made for that.
It might take a few tries with different chemicals - but without someone being able to look at it and determine the adhesive material used trial and error is the only advise I can give.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 10-24-2011, 06:47 AM   #6
Super Moderator
When I get a pop up ring that won't turn--I use channel lock pliers and grab the chrome ring ---
Be careful that you don't scratch the sink bowl---
I've never had that fail---However if it doesn't work for you--slide a hacksaw blade down the drain and slice the ring in a couple of places---that should break it free.
Worst case---Sawsall it off from under the sink.
Old 10-24-2011, 12:38 PM   #7
I tried vinegar with a toothbrush and scrubbed the inside and outside of the ring area. The result.....It worked! Thank you. Now onto the installation. I wonder how many problems I will encounter with this. I have never replaced a faucet but I am sure that is obvious
The Following 2 Users Say Thank You to Faucetguy For This Useful Post:
oh'mike (10-24-2011), Snav (10-24-2011)
Old 10-24-2011, 02:34 PM   #8
Military Mom of 4
Snav's Avatar
Voilla! Vinegar's awesome - I have gallons of it sitting around.
Your potential problems: very few - modern day faucets come with all the necessary tidbits. I've only run into odd problems when retrofitting a new faucet to a very old sink fixture. . .and so on.
If you replace it with a pop-up stopper my advice is to get a replacement metal slip and/or shaft if yours comes with a plastic one. Plastic slips tend to give and take and just aren't as solid - allow for the popper to pop out of the slip completely which is just obnoxious.
But at least you'll know - from here on out - how to fix one!
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
How to tie down header assembly? Pics bluefitness Building & Construction 18 11-23-2008 09:03 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 01:04 PM
