Old 10-13-2010, 11:26 AM   #1
pool pump fill then dumps water
My pool pump fills with water and the air (mostly) clears in the lines. Right before all air is out the pump sort of flushes all of the water out of the pump. Simultaneously the skimmer basket starts sucking water due to an extreme drop in the water level of the skimmer. FYI, the pool water level is good and the pump lid is tightly screwed on. Before I call the pool guy$ can anyone at least give me an idea as to what is going on? Thanks a bunch!!
nanderson360 is offline   Reply With Quote
Old 10-14-2010, 11:42 AM   #2
lloydb's Avatar
It really sounds like you have a leak on the suction side of your pump somewhere or maybe the gasket on your pump lid is messed up or missing. Or maybe a crack in the housing.
Broken Arrow hvac
lloydb is offline   Reply With Quote
Old 10-14-2010, 11:58 AM   #3
Thanks for your comment. I'll check the gasket around the sand filter as all other areas check out.
Tags
pool pump
New pool pump trips breaker?! New home owner needs advice. KenR7A Electrical 22 01-05-2011 10:42 AM
water borehole question joeuser General Discussion 2 04-18-2010 11:33 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
