Pool Heater Underground Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
View Poll Results: Pool heater size and gas line size
What size pool heater for 8000 gal pool? 0 0%
What size gasline for pool heater 60 feet from meter? 0 0%
Voters: 0. This poll is closed
Old 06-02-2013, 03:34 PM   #1
Lightbulb
Pool heater underground gas line
I want to install a pool heater. My pool is 8000 gal, my gas meter is 60 feet from my pool equipment. What size pool heater do I need and what size underground gas line do I need to run?
Mikehot is offline   Reply With Quote
Old 06-02-2013, 04:19 PM   #2
MarginallyQualified
Rewards Points: 2,464
My pool is 8000 gallons
What size pool heater do I need?
What is the incoming fresh water temp?
How warm do you want to make it?
What are the daytime ambient air temps
Do you have a night cover to keep it warm?
According to poolcenter... 100,000 Btu should suffice
...my gas meter is 60 feet from my pool equipment.
One Q at a time
Old 06-02-2013, 05:13 PM   #3
One Q at a time
Water temp 70 degrees. I want to make it 80-85degrees. I have a cover to keep warm. What size gas line do I need?
Old 06-02-2013, 06:53 PM   #4
Rewards Points: 2,038
1 inch min on low pressure.
Ghostmaker is online now   Reply With Quote
Old 06-03-2013, 05:16 PM   #5
FClef's Avatar
Rewards Points: 160
There is no hard and fast rule for your questions.
While a 100,000 BTU may suffice, if it runs forever to maintain the temperature you want, it can be an energy hog. Oversizing the heater too high will reduce efficiency because of very short run times and starts and stops. Any reputable pool company will be able to tell you what you need.
As far as the gas pipe size, that will depend greatly on several factors. You should never size gas pipe for intermittent load. You size pipe for maximum load meaning the potential for all of your appliances running at once.
If this is natural gas you should also find out if your current meter can handle the added load or if they need to increase it. If it is propane, then you can run a two stage regulated system meaning that you can have a high pressure regulator on the tank feeding 10 PSI and run a small line to a pressure regulator (11" WC) at the pool heater itself and then tie into the pool heater with black iron.
Two words of caution, number one... most places have a "One Call" system which you can call and the different utilities in the area (water, electric, gas etc) can come out and mark where their lines are BEFORE YOU GO DIGGING FOR YOUR UNDERGROUND LINE. The second word of caution is: I would NOT recommend that you do this work yourself unless you are ready to accept the risks of an improper installation. I do not make this suggestion to discourage you from doing the work yourself; I am merely saying that underground lines are not something that a homeowner should try to do themselves because too much can go wrong if not done correctly. So please, have a pro look at this and do the work. You can dig the trench for the line yourself if you want which will save you labor but I don't think doing the piping yourself is wise.
FClef is offline   Reply With Quote
Homemade electric pool heater taylorjm Electrical 11 04-22-2013 09:11 PM
gas line connecting to water heater young707 Plumbing 6 07-31-2012 06:36 PM
wiring gas pool heater - Ontario ESA 2buddy Electrical 0 06-12-2012 12:13 PM
New Underground Gas Line steve f Plumbing 20 03-04-2011 08:15 PM
Leak on gas heater water line? darsunt Plumbing 3 04-16-2008 03:57 PM
