Pool Backwash Outflow - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-16-2007, 12:16 AM   #1
Pool backwash outflow
Greetings--
Our new house has the pool's backwash/drain tied into the house's sanitary sewer. That's new to us. Our current house has the drain simply going out to the street.
What's the logic here ? Why drain it into the sanitary sewer ?
Piney is offline   Reply With Quote
Old 09-16-2007, 07:46 AM   #2
Send a message via AIM to Marlin
So your pool is draining to the sanitary sewer? That's completely illegal here, I don't know about there. Maybe your pool pre-dates the code that said you couldn't do it? Sort of like my gutters (installed in the 30s) still drain into my sanitary sewer although it's against code now.
Marlin is offline   Reply With Quote
Old 09-16-2007, 11:12 AM   #3
Eibwen
Could be somebody tied it in after the inspection such as a previous owner etc.. Dont sound right cause if your sewer line backs up it could contaminate the pool water.
I think I would change it to where it just runs to the street.
Sammy is offline   Reply With Quote
Old 09-16-2007, 12:37 PM   #4
Since the drain for the pool isn't constantly open (it has a valve) nothing can back up into it unless the valve is open. You need to check the local codes on it. Most likely it's illegal. You don't need to rush out and change it tomorrow though.
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Pool wiring jersey5.0 Electrical 4 10-07-2006 02:46 PM
Swimming Pool Light Broc Electrical 1 08-15-2006 03:23 PM
Pool Contractor Problem kevink Building & Construction 4 08-01-2006 10:46 PM
Pool Wiring phinfan1266 Electrical 4 06-27-2006 03:31 PM
