Poo Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-15-2008, 09:55 PM   #1
Exclamation
poo smell
i cant find the vent or whatever it is. i think its froze. i need to get the smell out of the house. its BAD.
dabander is offline   Reply With Quote
Old 12-15-2008, 10:43 PM   #2
Registered User
Termite's Avatar
This sounds more like a complaint than a question. You need to offer more specifics about what you've checked, what you think it is, etc...
Have you checked for dried out traps in floor drains, toilets, showers, or sinks that you don't use very often?
That's normally the issue when the house smells like poo.
Old 12-16-2008, 10:02 AM   #3
Unless you are seeing and hearing gurgling in your drains, it is probably not the vent. As stated, check for traps that may be dried out. Also check around the base of toilets for a broken wax seal that is allowing water to leak.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-16-2008, 11:00 AM   #4
Rewards Points: 1,910
Without more info these are the only things that come to mind:
1. Don't allow pets in the house.
2. Clean up the mess the pets made when they were allowed in the house.
3. Flush the toilets after use.
4. Stop eating gaseous foods.
5. Put soiled diapers into a container outside the house.
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 08:29 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
