-   -   poo smell (http://www.diychatroom.com/f7/poo-smell-33833/)
dabander 12-15-2008 09:55 PM
poo smell
i cant find the vent or whatever it is. i think its froze. i need to get the smell out of the house. its BAD.
Termite 12-15-2008 10:43 PM
This sounds more like a complaint than a question. :huh: You need to offer more specifics about what you've checked, what you think it is, etc...
Have you checked for dried out traps in floor drains, toilets, showers, or sinks that you don't use very often?
That's normally the issue when the house smells like poo.
majakdragon 12-16-2008 10:02 AM
Unless you are seeing and hearing gurgling in your drains, it is probably not the vent. As stated, check for traps that may be dried out. Also check around the base of toilets for a broken wax seal that is allowing water to leak.
jogr 12-16-2008 11:00 AM
Without more info these are the only things that come to mind:
1. Don't allow pets in the house.
2. Clean up the mess the pets made when they were allowed in the house.
3. Flush the toilets after use.
4. Stop eating gaseous foods.
5. Put soiled diapers into a container outside the house.
