Polyethylene Compression Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2012, 03:48 PM   #1
Rewards Points: 87
Polyethylene compression fitting
I have a 1/4" polyethylene line running to my fridge to supply the ice maker. The polyethylene was connected to a push-in type plastic connector that cracked reulting in a leak. The push-in connecter had a union and that was screwed into a standard stainless ice-maker line with o-ring fittings.
I want to eliminate the plastic to preclude any future failure as a result of cracking, so I purchased a 1/4" brass compression fitting and the brass insert for to prevent the polyethylene line from crushing.
My concern is with regard to the ferrule. The brass compression fitting has an integrated brass ferrule. Is this acceptable for polyethylene line or do I need to buy a brass fitting without an integrated ferrule and use a plastic ferrule for the polyethylene?
Thanks.
Tipsy
TipsyMcStagger is offline   Reply With Quote
Old 11-29-2012, 04:14 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Replace the whole line with a braided ice maker line.
Coastal South Carolina
Old 11-29-2012, 04:16 PM   #3
Rewards Points: 87
Thanks. That's not an option. The polyethylene is routed behind a baseboard.
Tipsy
Old 11-29-2012, 04:47 PM   #4
Experienced
Jackofall1's Avatar
http://www.kimsupply.com/Products/Co...male-Connector
This looks like its the answer to your question
Mark
Old 11-29-2012, 04:55 PM   #5
Rewards Points: 87
Thanks. If I were to go that route, I'd probably be better off with this since it would eliminate the need for a threaded union.
But I'm still interested in knowing the answer to my question regarding the use of a brass vs. plastic ferrule for polyethylene.
Tipsy
Old 11-29-2012, 06:18 PM   #6
Experienced
Jackofall1's Avatar
Push-lock fittings don't need a furl, you only use a furl and sleeve on a compression fitting the sleeve is to prevent the poly from crushing.
Mark
Old 11-29-2012, 06:25 PM   #7
Rewards Points: 87
Hence my original question. I'm not asking about push-lock fittings.
Tipsy
Old 11-29-2012, 06:29 PM   #8
Experienced
Jackofall1's Avatar
As long as you use the sleeve inside the tubing you will be fine with an integrated compression furl.
Old 11-29-2012, 07:50 PM   #9
Rewards Points: 582
always use brass connectors with plastic tubing and brass stiffners.... ben sr
Old 11-29-2012, 07:56 PM   #10
Rewards Points: 87
Thanks. I just put it together and the polyethylene blew out of the compression fitting when I turned the water on. I guess I didn't have it set properly because I reinstalled it and it seems to be holding fine now. No leaks.
Tipsy
The Following User Says Thank You to TipsyMcStagger For This Useful Post:
ben's plumbing (11-29-2012)
Old 11-30-2012, 12:20 PM   #11
Special User
Rewards Points: 1,230
This has not been my experience. Flooded the kitchen and stained nearby carpet.
You mean, no leaks YET. Ours silently blew when someone moved the fridge a few inches.
The way I made a secure polyethylene connection was to use the standard compression nut and brass insert, but THROW AWAY the brass ferrule and purchase a delrin or other type of plastic ferrule. So far, that seems to be holding.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 11-30-2012, 03:10 PM   #12
A "Handy Husband"
rjniles's Avatar
Running that poly tubing behind or thru cabinets is a disaster waiting to happen. Its not if it will leak it is when. And it will be when you are away for a few days.
Old 11-30-2012, 03:13 PM   #13
Special User
Does the PE tubing rub on the wood and wear a hole in itself eventually, or what?
Old 11-30-2012, 03:31 PM   #14
Rewards Points: 278
Tipsy
Attachment 61203
I have done it before and it works as long as it's not overtightened or undertightened.. How do we know this is not going to just pop out in the middle of the night?
Also I found the clear plastic kind sold at big box store kind of cheap and can split but the blue ones seem to be higher quality... (sold at water supply places)
DIYGST is offline   Reply With Quote
Trimming old pipe, adding compression fitting Chris84948 Plumbing 4 10-26-2012 08:23 AM
Compression fitting with copper tubing for dishwasher DK75 Plumbing 4 04-27-2012 06:47 PM
Easiest way to go from 1/2" ball valve to 1/4 inch compression fitting? Studly Plumbing 11 11-03-2011 07:57 AM
Leaking compression fitting help bob22 Plumbing 15 01-03-2011 03:04 PM
Compression fitting question JeffWireman Plumbing 9 03-07-2010 08:46 PM
