Polybutylene Replacement With PEX - Can This Be A DIY Project? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2012, 09:26 AM   #16
Originally Posted by rjniles View Post
You can also use Sharkbite couplings for this. Sharkbites are not rated for PB but they work (and are reusable) and you will only be using them temporarily.
SharkBite actually does have a fitting for transition from PB to copper/ CPVC/ PEX. They have two different colored ends. Make sure you're inserting the PB end into the GRAY side. The standard SharkBite coupling doesn't have an thick enough insert that's strong enough to support the PB pipe. Definitely keep a few of these on hand for your transitions, even if they're temporary.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
ActionDan is offline   Reply With Quote
My new carport & workshop project mgp roofing Project Showcase 64 01-13-2014 11:57 AM
Need help deciding on flat roof replacement... BeckyFL Roofing/Siding 1 10-17-2011 10:43 AM
Timbertech Radiance Rail project Ranger1227 Project Showcase 7 07-29-2011 12:59 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
What size nailer to use for Soffit Replacement Mach5 Roofing/Siding 2 01-28-2006 11:24 AM
