Polybutylene Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2012, 07:00 PM   #1
polybutylene problems
I live in a older mobile home and it uses polybutylene tubing.The shutoff valve for the toilet does not work any more so I need to replace it and the line to the ballcock.What is the best way and material to do this.Thank you for your help.
JamesW is offline   Reply With Quote
Old 05-26-2012, 07:57 PM   #2
Rewards Points: 12,818
There was class action law sutes againt the companys that made Quest tubing because of all the leaks and fittings failing.
Replace it all with Pex.
http://polybutylenelawsuit.com/pictures.htm
JamesW (05-29-2012)
Old 05-26-2012, 09:35 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 348
I use a PEX x PB adapter and a pex supply valve. You will need a pex tool also. You can rent them.
Also, PB has a history of failing so set aside some money so you can repipe your home soon.
The Following User Says Thank You to TheEplumber For This Useful Post:
JamesW (05-29-2012)
Old 05-26-2012, 09:41 PM   #4
That's why I suggested replacing all of it instead of the adapters.
Cheaper to do that then distory the home from a pipe bursting.
Most manufactured homes use partical board subfloor. One pipe busts and we all know what happens.
JamesW (05-29-2012)
Old 05-26-2012, 11:51 PM   #5
Plumber
Rewards Points: 348
True, but the guy wants to use a toilet for Pete's sake
JamesW (05-29-2012)
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Owen or Certain Teed has less problems?? reeses Roofing/Siding 10 02-07-2009 09:35 PM
Determining whether or not you have foundation problems? rmartin1286 Building & Construction 8 01-23-2009 09:09 AM
steam heat problems alanliz HVAC 8 01-18-2009 09:10 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
