Polybutylene Pipe Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2007, 11:28 AM   #1
Unhappy
Does anyone know if Polybutylene Pipe will accept standard PVC fittings? I need to replace some leaking connections and want to make sure I can replace the leaking ones with regular PVC.
Someone told me that you have to use specail compression connections to make such repairs. Its that is true where do you get them?
williamsmithaud is offline   Reply With Quote
Old 01-23-2007, 02:13 PM   #2
call a plumber if you aren't sure
gitnerdun is offline   Reply With Quote
Old 01-23-2007, 06:27 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
What color pipe is it?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 06:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Pipe repair compound? redline Plumbing 3 06-07-2006 05:50 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
