Old 04-12-2006, 01:50 PM   #1
polybutylene
I have a water leak in my ceiling.I'd rather not tear out the whole ceiling to replace all of the polybutylene.Do compresson fittings work with polybutylene?Can you glue pvc to polybutylene?I can't seem to find polybutylene fittings.Any suggestions are appreciated.
wiggs is offline   Reply With Quote
Old 04-12-2006, 02:45 PM   #2
Doing it myself
Alan's Avatar
polybutylene
Certainly gluing different types of pipe together is not really something that would be acceptable as far as building codes go.
It probably won't work if the pipe in question is under pressure, you'll end up having a large margine for failure of the glued joint. However, i've seen people glue all numbers of different style of plastic pipe together for drains. Again, i'm not saying its right, but for a drain it will more than likely work.
Old 04-12-2006, 03:11 PM   #3
polybutylene
The pipe in question,is under pressure.After I posed the question I went to the plumbing supply house.They had brass compresson fittings,which I've never seen before.You just push the pipes in the fitting and it holds like crazy.You can't pull them apart.It's holding for now.Only time will tell.
Old 04-13-2006, 11:14 AM   #4
electric & plumbing contr
polybutylene
If you have PB piping in your home, I would advise you to do a little research. The material has a history of failures and has been the subject of several lawsuits.
You can start here:
http://www.polybutylene.com/
Or just google it. You'll get a ton of hits.
Good luck.
Atricaudatus is offline   Reply With Quote
Polybutylene Pipe Repair williamsmithaud Plumbing 2 01-23-2007 07:27 PM
