Polybutene - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2011, 03:52 PM   #1
polybutene
How do I tell the difference between polybutene piping and pvc piping
dkoby is offline   Reply With Quote
Old 06-14-2011, 04:02 PM   #2
Experienced
Jackofall1's Avatar
If not experienced with inspection or plumbing it is difficult to tell them apart.
Here is site that explains the differences
http://propex.com/C_f_env_polybu.htm
Old 06-14-2011, 04:21 PM   #3
Rewards Points: 3,130
I have only seen polybutylene in a couple of homes (unfortunately, one was mine). In both cases, it was gray. All the valves and fittings were attached with crimp connectors. PVC is pretty much always glued or has threaded connections. And if what you're trying to identify is used for hot water, it's not PVC (at least it shouldn't be.). Not code approved for that.
