Poly Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2012, 06:51 PM   #1
poly pipe
Is 160 psi rated pipe efficent to carry potable water from meter to residence, or is 200 psi rated pipe advisable? Distance is approx. 200 ft. Should of mentioned that existing water pressure in that area is 67 psi. Thanks for any advice.
Ron
Last edited by Ron S.; 10-23-2012 at 06:54 PM. Reason: water press. very important!
Ron S. is offline   Reply With Quote
Old 10-23-2012, 06:58 PM   #2
Civil Engineer
Rewards Points: 4,568
You should check with the local utility to see what type of pipe is required. They should be able to advise you what schedule pipe is required, and the best type of material to use.
Old 10-23-2012, 08:43 PM   #3
Rewards Points: 582
Ron
200 psi pipe is available..but as was mentioned check with water supplier for what they want.....if you only have 67 psi 160 would be plenty..with room to grow...ben sr
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 06:53 AM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 09:00 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
