Poi While House Water Filter Pressure Drop - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2014, 10:13 PM   #1
poi while house water filter pressure drop
We have installed a whole house water filtration system for our well. The water goes from the well pump into a pressure tank (with a pressure gage installed before entering). It then goes into big blue 20" 20 micron sediment filter followed by big blue 10" 5 micron sediment filter, entering the pelican 600 carbon filter and then sterlight UV light. When the water is pumping through the filters there is noticeable pressure drop at the end it goes from good gushing to trickling and running down the hose. And there is also fast on and of switching of the well pump. All parts besides the well pump are new.
What could be causing suck a drastic water pressure drop?
1miki23 is offline   Reply With Quote
Old 08-19-2014, 04:27 PM   #2
Rewards Points: 1,548
Is the pressure tank properly pressurized and without sediment inside clogging the outlet pipe?
The pressure tank should be set to a few PSI less than pump turn on pressure while the rest of the system has been depressurized, pump off and a cold faucet open.
Old 08-19-2014, 05:44 PM   #3
Rewards Points: 14,306
Short cycling is almost always a pressure tank issue.
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
huge water pressure drop from sprinklers rockstar Plumbing 7 09-17-2012 05:38 PM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
