Plunger Style Drain Stopper Stuck - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2008, 11:42 AM   #1
Plunger style drain stopper stuck
I've got a plunger style drain stopper that isn't moving...Water drains, so that's a relief. I've been using a rubber stopper in the drain as a band-aid when I want to fill the tub, but now that I'm trying to sell the house, I'd like to get it working (inspector noted it on a report...really? a drain stopper not working!!?)
I found this site:
http://www.lowes.com/lowes/lkn?actio...RepTubDrn.html
Unfortunately, when I try to pull out the assembly, the plunger doesn't move which keeps me from accessing the adjustable lock nut. Of course, there's no access to the pipe w/o yanking the tub. Any ideas what it might be hung up on? Possible corrosion freeze from being in the same place for so long?
engineerdixson is offline   Reply With Quote
Old 06-07-2008, 11:56 AM   #2
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Engineer,
Most likely it's just stuck from all the hair and gunk that has built up over the years. Try wiggling, jiggling and twisting back and forth (I know that sounds stupid but it's accurate) as you pull upward on the assembly. Some of these have cotter pins and screws that get hung up inside and it requires a fair amount of patience to remove them.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 06-08-2008, 07:51 AM   #3
mstplumber,
Thanks so much for the advice. After much pulling and tugging (and yes, twisting) it finally came free. I've broken alot of things over the years by using too much force and was worried I'd break the linkage if I was too aggressive. Looks like all I needed was the encouragement that the linkage shouldn't break. It popped free and now works great.
Take THAT home inspector!
Old 06-09-2008, 07:38 AM   #4
mstplumber's Avatar
Rewards Points: 150
you're welcome
Mstplumber
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
drain stuck how to remove tverhoef Plumbing 1 03-14-2008 06:53 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
floor drain with a stopper amakarevic Plumbing 3 08-13-2007 01:12 PM
