Old 06-28-2012, 05:51 PM   #1
Plunger for Elongated Toilet
I have 2 of the new low flow, elongated toilet bowls. (Lucky me ) Wife insisted..
A typical plunger will not work on them since I can't get a seal since this is elongated. I did use an auger to clear a clog but would rather use a plunger if there is one that will work with this style toilet.
Any recommendations or brand names? I have been to the big box stores, hardware stores they say..all that I can use is an auger.
Hope you guys have some suggestions.
Tx,
Tom
roztom is offline   Reply With Quote
Old 06-28-2012, 11:06 PM   #2
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
THIS IS THE STYLE I HAVE
USED ON BOTH ELONGATED
AND ROUND BOWL
WORKS GREAT ON BOTH
HYDRO THRUST
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 06-28-2012, 11:15 PM   #3
Thanks... this has a long, not round drain - like a scoop... none of the round plungers I have can get a seal since the scoop part of the toilet is too long.
Is the rubber soft enough on this one to countour to it and cover it up for a seal?
Tx,
Tom
Old 06-29-2012, 01:04 AM   #4
Easy, buy a standard toilet plunger and remove the short handle then replace with a wooden broom handle.
epson is offline   Reply With Quote
Old 06-29-2012, 09:07 AM   #5
It's elongated, almost like a gravy boat (Don't blame me..) with the narrow part towar4ds the front...even the largest traditional round plunger won't cover all of it so no seal... I guess their isn't something you guys can use other than an auger... ?? ?
Tx
Tom
Old 06-29-2012, 09:12 AM   #6
MACPLUMB's Avatar
yes that is why it works so good
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
New Plunger, but Ballcock is Still Leaking in Toilet Krell Plumbing 8 09-03-2011 03:48 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Unused toilet - clogged? co2 plunger? Tommy2 Plumbing 16 12-02-2008 04:06 PM
