Plumping - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-26-2012, 12:42 PM   #1
plumping
compression fitting from copper water supply to plastic fitting leaks,why
gramparichie is offline   Reply With Quote
Old 08-26-2012, 12:51 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
Be a little more specific, picture will help. few reasons for compression fittings not sealing.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-26-2012, 12:54 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Might be due to improper plumping.
Journeyman Plumber
Old 08-26-2012, 08:52 PM   #4
Happy to help
Lighting Retro's Avatar
Outside diameter of the two types of pipe can be different if you haven't bought the right fitting. Might consider sweating a copper fitting on, and then using a thread to compression fitting to the PVC if you are stuck on that method.
Lighting Retro is offline   Reply With Quote
Old 08-26-2012, 09:06 PM   #5
Rewards Points: 13,994
Plastic could mean PVC, Quest, Pex, Poly, and a 1/2 dozen others.
By far compression fittings are the most prone to leaking.
Give us some details and there may be a better way.
plumping bert701 Plumbing 2 02-24-2012 06:39 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
