Pluming, Hot Water Hear Popping - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2012, 12:20 PM   #1
Red face
pluming, hot water hear popping
My hot water heater when it ignite make a woop sound like it's not lighting fast enough when it's supposed to. works fine after it ignites.But each time it make wooping sound when it relights. It is a butane gas heater.
what advise can you give me/ thanks,
will k
WEKBREW is offline   Reply With Quote
Old 03-23-2012, 01:11 PM   #2
MarginallyQualified
Rewards Points: 2,464
what advise can you give me...
To some degree almost all WH's will do this.
That said...
1) Have the Butane company in for a check up.
2) Arrange at least an ANNUAL check up visit (Fall).
The Following User Says Thank You to TarheelTerp For This Useful Post:
WEKBREW (03-23-2012)
Old 03-23-2012, 01:58 PM   #3
hot water heater
My hot water heater make a woop sound when igniteing woomp like it want to explode it pretty loud it is a
propane gas heater.
What shall I do?
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 04:43 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 07:46 AM
