Pluming - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2013, 11:26 PM   #1
pluming
what is the best way to reduce 3/4in hose from a pump to 5/8 so that i can attach a garden hose to it
brewmaster01 is offline   Reply With Quote
Old 02-18-2013, 07:28 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 608
Ayuh,.... Just put yer pipe to hose fittin' on the pump, 'n run 3/4" hose the whole way...
Or,...
Attach the 5/8" hose there...
Garden hoses, 1/2", 5/8", 'n 3/4" all attach with the same threaded fittin's...
Old 02-18-2013, 09:42 AM   #3
Rewards Points: 13,296
3/4" hose? DO you mean something like 3/4" copper or Pex pipe?
More info or better yet a picture sure would help.
Old 02-18-2013, 08:08 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Hose fittings are 3/4" regardless of the size of the hose. If you have 3/4" pipe fittings on the pump, you need a 3/4" pipe to 3/4" hose adapter.
Coastal South Carolina
Old 02-18-2013, 09:06 PM   #5
Rewards Points: 3,130
I'm pretty sure he means a hose. Copper isn't a hose, and Pex isn't a pipe.
Old 02-19-2013, 12:36 PM   #6
Building tradesman
try to help
When you say 3/4 hose, what type of hose are you referring to. Like a auto heater hose?, or cut off garden hose?, or water heater flex line??
And go to 5/8 are you talking about a cut off length of garden hose?
What is the outlet of the pump? Female pipe thread, barbed, male pipe thread??? If it is a female pipe thread, obtain a mpt x mht. The mht is a male hose thread and they are all 3/4". The mpt is a male pipe thread and a standard fitting is a 1/2 mpt x ght.
If pump is male pipe thread out, add a coupling in between.
If it is a barbed fitting it will likely be screwed into the pump.
Now if it is a hose only out. Home supply would have hose repair fittings for your 1/2, 5/8, and 3/4 inch hoses that are available in fht/repair, mht/repair, or coupling. I doubt you will be able to go to 3/4 from 5/8 with a repair coupling instead having to go to repair/hose thread at which point you can add standard garden type hose.
PS spring for the brass fittings instead of the cheap plastic. Only have to buy once.
dudleydoright is offline   Reply With Quote
pluming, hot water hear popping WEKBREW Plumbing 2 03-23-2012 02:58 PM
Dishwasher pluming help Holt Plumbing 6 05-07-2010 03:59 PM
Pluming Hot Water Turning Cold - Help! kissiffer4 Off Topic 1 01-14-2010 06:00 PM
pluming with PEX dudley123 Plumbing 1 03-16-2008 06:42 PM
Please...Help! connecting rough pluming tverhoef Plumbing 12 02-25-2008 06:01 PM
