Plumbling - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2013, 05:07 PM   #1
plumbling
how do I check and fix back flow problems
ladyd is offline   Reply With Quote
Old 02-15-2013, 05:10 PM   #2
Lightfoot's Avatar
Rewards Points: 272
you will need to be a little more specific as to what particular problems you are having, then i'm pretty sure you'll find the help you need here
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
Old 02-15-2013, 10:01 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Before you go too much further "Backflow" usually refers to a potential hazard in a water system requiring a device to be installed to prevent contamination of the water.
If this is what you're having a problem with, please elaborate as to what exactly is wrong with your backflow device
If not, please try to describe the problem you ARE having in a little more detail so we can determine what is actually going on.
Journeyman Plumber
Old 02-16-2013, 05:25 PM   #4
Lightfoot's Avatar
Rewards Points: 272
Well Alan, either the backflow (whatever that is) blew up and took out the OP, or it was yet another "google post" we weren't quick enough to answer.
Old 02-16-2013, 06:50 PM   #5
Rewards Points: 13,694
"plumbling" Hay she spells as bad as me.
Old 02-16-2013, 08:13 PM   #6
google post? What exactly do you mean?
paintdrying is offline   Reply With Quote
Old 02-17-2013, 01:12 AM   #7
Lightfoot's Avatar
Rewards Points: 272
a person googles a plumbing problem, this site comes up. They post a question (thinking it's a chat room), nobody answers the question immediately, the OP is never heard from again. that's a "google" post
Old 02-17-2013, 02:40 AM   #8
747
registered
747's Avatar
Rewards Points: 534
Be more specific. What do you mean by back flow. WHAT EXACTLY IS GOING ON.
747 is offline   Reply With Quote
main water valve or pressure regulator kzwbvn Plumbing 5 10-21-2011 06:40 AM
