Plumbing A Washing Machine In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2011, 11:48 AM   #1
plumbing a washing machine in basement
I am planning on moving my washing machine into my basement, there is a sewer line with a 4 inch clean out near by which runs to the septic tank by gravity. Can I install an adapter into the clean out and then run the washer drain though a p trap and then into this drain?I would really like to find out how do to this right if this will not work.
Chris Chapple is offline   Reply With Quote
Old 01-30-2011, 12:18 PM   #2
Yes- Take the cleanout cap out. Add a fitting there then put a Y in with a clean out in it. Then run your pipe over to the washing machine. Put a p-trap in line-- ohh make that drain a 2in line. You really should hook a vent to it. Without seeing it I can't tell you were a vent is to hook into. Hope that helps.
proremodel is offline   Reply With Quote
Washing Machine Drain Pipe overflows evol200 Plumbing 3 01-27-2011 12:41 PM
Plumbing a Washing Machine Drain MikeWood Plumbing 2 01-21-2010 07:10 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
Washing machine lint filter Dragonladie Plumbing 4 10-19-2008 06:52 PM
Can a newbie move over a washing machine? yummy mummy Plumbing 17 02-15-2007 07:31 AM
