Plumbing For Washing Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2008, 05:16 PM   #1
Plumbing for washing machine
Our washing machine drains into a large utility sink via an exposed hose which hooks over the edge of the sink. We're re-doing the room, replacing the appliances, and I'd like to know what would be involved to "hide" the hose. Thanks!
jgmn is offline   Reply With Quote
Old 04-26-2008, 06:17 PM   #2
Registered User
Termite's Avatar
Well, you can't just tap in to the drain for the sink...Unfortunately.
You need a 2" drain, as well as a trap and a standpipe. Do you have unfinished space beneath the laundry room and reasonably good access to existing larger drain lines?
There are some pretty slick laundry boxes that mount into the wall and incorporate the drain with the supply lines. You could install such a box and not install new supply lines if you like where the existing ones are at.
If you're not an experienced plumber this might not be a DIY job.
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 07:37 PM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 09:36 PM
Help Plumbing in Coffee Machine singforsupper Plumbing 2 08-19-2006 10:28 AM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
