Plumbing Vents / New 2nd Floor Ensuite - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2012, 10:48 PM   #1
I am converting a second floor walkin closet to an ensuite. There are two exterior walls in the room. A 3" pipe is possible to the basement but it can not cleanly continue to the roof. I can connect to the existing vent pipe in the attic. I am not sure of the best/easiest way to properly vent the proposed shower stall/toilet and vanity sink through the walls. I reside in Ontario Canada. Help.... I have attached a rough diagram.
Grambo is offline   Reply With Quote
Old 01-31-2012, 11:03 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Here in the states you must run a 3" up for the toiet at a min. Then you may reduce the pipe size by 1/2 the pipe area for the vent. So you could use 2" pipe up the wall to connect the lav and then through the roof.
I thinking it will be pretty close to canada rules but not sure. If you don't get a response check with your local code department
3" = 7.0685 sq in area
2" = 3/1416 sq in area
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-01-2012, 12:01 AM   #3
Yup, min 2" vent for what you're proposing per National Plumbing Code. Check with local authorities, as they may be more restrictive.
VIPlumber is offline   Reply With Quote
Old 02-01-2012, 12:33 AM   #4
Rewards Points: 626
I would use a a AAV or what known as a Air Admittance valve you place between the fixture and the drain pipe and you have to have access to the valve because that can fail and be replaced but it saves time and money and frustration on running new vent stacks. and AAV's you have to go to places like Ferguson's or other plumping out let stores not your lows or home depot or ace hardware.
Nailbags is offline   Reply With Quote
Old 02-01-2012, 09:15 AM   #5
Rewards Points: 150
I don't have all your answers, so I will pose a few questions that may help you:
1)What is the maximum length for the 3" toilet branch to the stack?
2)What is the proper way to vent the toilet in this application?
3)Can you run 2" drain from the shower and pick up the lav, and use the lav as a wet vent for the shower? If so, what is the max. distance from the shower to the wet vent?
4)Can you run vents through exterior walls?
I am asking these questions to better help the OP get all the facts.
psilva8 is offline   Reply With Quote
Old 02-01-2012, 12:11 PM   #6
Hi, Not sure of the correct answers for #1 and #2. Question #3 sounds possible. I still need to figure out how to vent the toilet properly. Question #4, note sure of the answer either. I was hoping someone could look at my sketch and draw in the suggested plumbing vent lines.
Hidden Soffit Vents Mucluk Building & Construction 4 01-26-2012 09:15 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
vents for what? hohadcr Building & Construction 3 08-25-2009 07:29 PM
ridge/soffit vents not enough?? cbice74 Roofing/Siding 1 06-16-2008 06:02 PM
