Plumbing - Venting Bathroom - Please HELP - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2011, 09:49 PM   #1
We are reconfiguring our bathroom. We have a 1.5" vertical vent to the roof from the vanity/bathroom sink. The tub is right next to it, so that will be vented to this 1.5" pipe as well. No worries there. The question is on the shower and toilet.
1)Can the shower (2" drain) be dry vented to the 1.5" vertical vent pipe? The shower drain vent is across 2 walls, about 3' then 90 degree turn, running about 7', then 90 degree turn, running about 4' to the 1.5" vertical vent. Total of about 14'
2)Can the toilet be vented to the 1.5" vertical vent pipe? The issue is the toilet drain (3") is 5' then 90 degree turn, running another 4.5' to the wye stack, total of 9.5' from toilet drain to wye stack (4"). Since this distance is more than 5', can we go in the other direction, venting this to the 1.5" vertical vent that everything else in the bathroom is vented to? This distance is about 3' from toilet to 1.5" vertical vent pipe.
Thank you!
garysacco is offline   Reply With Quote
Old 12-08-2011, 10:32 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
I'll give you answers per my code(UPC)
1. A shower requires a 1.5" vent. I don't follow your described routing tho.
The shower, lav, and tub can all fit on a 1.5" vent too, but the horizontal portion is limited in length.
2.W.C. requires a 2" vent. At the point where you connect to the 1.5" vent stack (42" above floor), increase to 2" through the roof
Hope this helps
Old 12-09-2011, 09:38 AM   #3
Thank you for your response. One quick clarification: I understand the W.C. needs a 2" vent. Are you saying I have to remove the 1.5" vent that goes 2 floors up, to the roof, and replace it with a 2" vent? Or can I use a 2" vent from the W.C., connecting it to the 1.5" vent with an adaptor?
Old 12-09-2011, 09:58 AM   #4
Plumber
Rewards Points: 452
A toilet requires a 2" vent. You cannot legally decrease a vent size. So it must be a minimum 2" through the roof. Would it work on 1.5? prolly, but the inspector won;t like it.
Old 12-09-2011, 10:31 AM   #5
Rewards Points: 3,130
Do you know what the applicable plumbing code is for where you live? The UPC and IRC approach venting in very different ways. For example, under the IRC no vent at all is required for a toilet. Also, air admittance valves are permitted under the IRC but not the UPC. My house is plumbed per the IRC (did it myself) and everything passed inspection and works just fine.
Adding a Bathroom in a bungalow attic - Toilet Venting awpurcell10 Plumbing 4 06-08-2011 08:22 AM
Bathroom Plumbing Rough-In dandw12786 Plumbing 2 07-12-2010 06:13 PM
Venting a bathroom Cossack Plumbing 10 06-27-2010 04:07 PM
Basement bathroom under slab plumbing garynlisa Plumbing 0 02-01-2010 11:04 AM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 09:30 AM
