Plumbing Vent Through Side Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2012, 12:13 PM   #1
plumbing vent through side wall
hi, I am about to install a new roof and would like it to have ZERO openings through it.
I understand that there are good vent flashings out there and if installed properly they can last a long time without leaks. However, i would like to reduce chance for leaks as much as possible, so I would appreciate if you keep your answers on target.
Can I run a plumbing vent to the side of the house? I would probably run a pipe around the eve above the roof (but not through the roof). I am also not concerned how it will look. Any issues with this?
I know the code requires at least one vent THROUGH the roof but i would go AROUND.
I am in St Petersburg, Florida.
Any practical or code issues here?
Thanks.
basan is offline   Reply With Quote
Old 03-24-2012, 01:50 PM   #2
Rewards Points: 2,238
Check with your local Building Dept.
Through a wall? - how far from any windows/doors?
Any roof penetration, if done correctly, will/can outlast the life of the roof.
"RF"
You say "zero openings" - got any vents?
rossfingal is offline   Reply With Quote
Old 03-24-2012, 02:31 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 990
Under the IPC which is what we are under the answer to your question is no.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-24-2012, 02:37 PM   #4
"Javiles"
Thank you!
"RF"
Old 03-24-2012, 02:39 PM   #5
it would go trough "gable wall".
There are doors and windows but that should not be an issue because vent pipe would be above the roof - correct?
instead going strait through the roof it would have two 90 degrees elbows going AROUND eve and above roof.
bath/kitchen exhaust vents will go through side and i will have ridge vent.
electrical entrance will probably go through roof so it would actually be 1 opening
Old 03-24-2012, 02:42 PM   #6
can you explain why please? is it because of the two elbows?
Old 03-24-2012, 03:00 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 990
Any stack that you off set will now require a cleanout at the base of that stack, also distance from the fixtures needs to be accounted for. in some areas visual appearance will also prohibit that installation. That vent stack serves multiple purposes. Neutralizing pressures in the plumbing system. Access to the drain system. And sewer gas drafting. When the plumbing in that home was designed and approved all those thing were taken in to account modifying that layout is in its self a code violation, Get a good reputable roofer; make sure he pulls permits, the flashings get inspected, no reason for concern if all the work is done correctly.
The Following User Says Thank You to Javiles For This Useful Post:
rossfingal (03-24-2012)
Plumbing a 2x4 Exterior Wall batdude Plumbing 5 01-03-2011 08:21 PM
To seal/cap a wall with plumbing in it, or not... bkraz Building & Construction 6 12-15-2010 08:31 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
Vent stack is on other side of basement... Feretich Plumbing 5 02-12-2010 02:13 AM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 01:01 AM
