Plumbing Vent (Stack) Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2010, 05:12 PM   #1
Unhappy
Plumbing vent (Stack) leak
I live in a home from the 1970s that has a mansard roof. (Flat roof, not attic access, in fact the space is only 12 inches high)
We have had roof repair people come to seal the perimter of the flat roof, replace the scupper (water drain) and to install new plumbing boots around the plumbing vent pipes. All of this was sealed properly. During the first heavy rainfall after that, there was a new leak and all the old ones were back. We have pretty much ruled out a roof problem and are now wondering whether the plumbing vent pipes might have shifted. One reason is that the new leak appeared in the following manner: during the rainfall I heard dripping noises in an inside wall - the one and only one that goes all the way from the roof to the basement. We subsequently found water almost directly below in the basement, 2 floors down.
The experts have not returned and I am wondering how they would diagnose the problem. A small camera perhaps, or do the walls need to be opened up? Could the same pipe be responsible for the ceiling stains too? (Apparently the old flat roof was not removed when the new one was installed, so it is possible that water flowed in between the two until it found a spot to pool.)
Does anyone have experience with such a problem?
lizziefl is offline   Reply With Quote
The Following User Says Thank You to lizziefl For This Useful Post:
triplex (02-11-2012)
Old 02-11-2012, 01:49 PM   #2
Rewards Points: 27
RE: Plumbing Vent Leak
I am having the exact same problem in exactly same type of house. Would you be able to tell me how you found the cause and how you fixed it? We just had our entire roof replaced in the summer and now we are having these type of leaks. Is the roofer who did the roof responsible for this or do we need to call a plumber? I would appreciate any help on this. Thank you!
triplex is offline   Reply With Quote
Old 02-11-2012, 01:57 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Does the stack follow that exterior wall from basement to roof?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-11-2012, 02:05 PM   #4
Rewards Points: 27
It's an interior wall. I'm not really sure...and I'm not handy at all.
Old 02-11-2012, 02:08 PM   #5
plummen's Avatar
Well we need some pictures from 1 of you to figure out what youre up against
Old 02-11-2012, 03:46 PM   #6
Rewards Points: 27
I have a lot of pictures can I email them privately?
Old 02-11-2012, 03:57 PM   #7
plummen's Avatar
You can post them up here
Old 02-11-2012, 04:16 PM   #8
Rewards Points: 27
more pics to follow....
the first one is the old roof and the next 2 are the new roof...the flashings were replaced as well...the pic was taken before they were replaced.
After the roof was finished we realized the roofer did not put a vent for 2 bathrooms. We had him come back and he had to put a new gooseneck right next to one that is actually useless now! So that involved opening up the roof again. The leaking is happening in this area. We had the roofer come back and he said the roof was fine and that we needed to check the vent pipe.
Plumbing vent (Stack) leak-078.jpg   Plumbing vent (Stack) leak-079.jpg   Plumbing vent (Stack) leak-081.jpg   Plumbing vent (Stack) leak-168.jpg   Plumbing vent (Stack) leak-171.jpg
Old 02-11-2012, 04:22 PM   #9
Rewards Points: 27
The next 6 pics are just showing how we had to open up the roof again to have the vents for the bathroom fans. The wall we are hearing the dripping noise inside when it rains is the interior wall. This triplex is attached to another triplex.
Plumbing vent (Stack) leak-174.jpg   Plumbing vent (Stack) leak-180.jpg   Plumbing vent (Stack) leak-182.jpg   Plumbing vent (Stack) leak-184.jpg   Plumbing vent (Stack) leak-185.jpg
Old 02-11-2012, 04:32 PM   #10
plummen's Avatar
Take a hose up on the roof and stick it down one of the roof drains in that area while somebody inside listens for water,then check around the areas other stuff comes through roof with the hose
Old 02-11-2012, 04:33 PM   #11
Rewards Points: 27
The next pics show the water damage coming down to the basement level. We have a main floor and the basement level. Above us, is a tenant that hears the water dripping inside his wall. We hear it in our bathroom wall as well and are starting to see some water damage there. In the tenant's bathroom the ceiling is starting to show some moisture and underneath the wall where they hear dripping is a baseboard heater. There has been moisture and some water underneath there as well.
Before we started hearing dripping in the wall we used to get water leaking into our basement. The tenant changed his shower handle and the ring for the toilet and then it stopped. Then later, when we had lots of rain and wind we got the leak again and hearing the dripping inside the wall. We turned off the main water valve and you could hear the dripping as long as it was raining.
Plumbing vent (Stack) leak-188.jpg   Plumbing vent (Stack) leak-189.jpg   Plumbing vent (Stack) leak-221.jpg   Plumbing vent (Stack) leak-222.jpg   Plumbing vent (Stack) leak-224.jpg
Old 02-11-2012, 04:37 PM   #12
plummen's Avatar
Is it a plumbing stack or a roof drain running down inside that wall?
Old 02-11-2012, 04:38 PM   #13
Rewards Points: 27
would you say though that this is a plumbing or roofing problem? After we check with the hose who would you call? And do you think opening up the roof the second time could be a cause?
Old 02-11-2012, 04:39 PM   #14
plummen's Avatar
Since the drywall is already screwed up id cut an access hole in the highest point in that area you can reach and start investigating.
If it wasnt leaking before the roof was replaced id still start looking around where the pipes exit/meet roof myself for the leak
Old 02-11-2012, 04:41 PM   #15
plummen's Avatar
If it leaks when you shove a hose down inside the pipes id say plumbing,if its where the 2 meet id say roofer
Bath P-trap related to tee and stack vent Jim F Plumbing 2 03-29-2010 11:04 PM
PEX plumbing inspection and vent line ideas jeste Plumbing 2 02-10-2010 06:35 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
tub vent leak coax Plumbing 2 03-21-2005 11:59 PM
