Plumbing Vent Was Covered - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2010, 06:24 AM   #1
Plumbing vent was covered
We have lived here for 2.5 years. I was up on the roof two summers ago, and noticed the two plumbing vent stacks still had a plastic cover on them. I knocked them off, and of course, being old and brittle, some of it went down the tube. I was a little more careful with the second one.
Why would these be covered? We are on a septic system, but I called my in-law, who is out in the country as well, and he said his were not covered. Any ideas? Last roofing job just forgot to remove?
Bill7 is offline   Reply With Quote
Old 01-12-2010, 07:54 AM   #2
47_47's Avatar
Rewards Points: 62
The vent must be exposed to the atmosphere. Did these covers still allow air to enter? If they did they may have been installed to prevent bird or insect nesting from blocking the vent.
47_47 is offline   Reply With Quote
Old 01-12-2010, 08:47 AM   #3
Many Plumbers install a cap on the pipes going through the roof to avoid roofers throwing junk down them. This sounds childish, but happens. Also, they may have been left on after the drainage system test and inspection (by accident).
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-12-2010, 08:53 PM   #4
firehawkmph's Avatar
Rewards Points: 1,898
Originally Posted by majakdragon View Post
They may have been left on after the drainage system test and inspection (by accident).
Bingo.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-16-2010, 05:26 PM   #5
I think this happens more than people think! I've seen it so many times, Usually they are blue, around here anyway.
reuter is offline   Reply With Quote
Old 01-16-2010, 07:49 PM   #6
What happens is the plumber does the rough plumbing in a new house under construction and caps off the stacks and uses the inflatable rubber balls inside to seal everything up for the air test. The inspector comes out and inspects and passes it. The plumber removes the inflatable balls but if the weather is lousy that day, doesn't go up on the roof to bust out the plastic caps. Then a year or two down the road somebody is up on the roof for whatever reason and notices them and busts them out. It doesn't usually affect the operation of the drains where you would notice anything amiss.
Mike Hawkins
Removing Plumbing Vent from Roof WaldenL Roofing/Siding 5 08-24-2009 02:30 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
