Plumbing Vent In Basement Laundry Room - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-08-2013, 07:35 AM   #1
Rewards Points: 89
I will be making a laundry roomin my basement (plumbing is not my expertise). I have spent quite a bit of time reading codes and plumbing books prior to posting here.
In regards to the venting I am about 4 feet from the "sewer pipe" that goes to the city sewer line.
The image in one of the books does not show a dedicated vent by the sink. From what I have read I should put one in, or does the waste stack act as a sufficent vent?
tjfslaughter is offline   Reply With Quote
Old 05-15-2013, 07:28 AM   #2
Rewards Points: 89
bumpty
Old 05-15-2013, 08:08 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 542
I don't think that image is legal in any code. The waste stack is not a vent
Old 05-15-2013, 08:21 AM   #4
Rewards Points: 89
That is what is nuts. Its in a book called "codes for homeowners"....
Old 05-15-2013, 08:39 AM   #5
Rewards Points: 2,516
If what is labeled as waste stack does not have any fixtures draining into it above the San-T for that utility tub, then that setup would suffice as a vent for the utility tub trap
hammerlane is offline   Reply With Quote
Old 05-15-2013, 08:45 AM   #6
Plumber
Rewards Points: 542
Then the book should have labeled it vent stack
Actually, it's not uncommon to see this layout all over my town- it's way it was done back in the day...
Old 05-15-2013, 08:52 AM   #7
I agree.
Old 05-15-2013, 10:42 AM   #8
Rewards Points: 89
Here is what I know:
1. The sewage pipe in the basement is makes a turn and goes striaght up to the attic
2. The kitchen and first floor bathroom drain into this pipe (at a junction in the basement on the other side of the wye that goes upstairs)
3. The second floor bathroom drains into this pipe through a wye
"Chicago-Loop" For Shower & Laundry Room Vent spaceboy Plumbing 3 10-26-2012 07:41 AM
Installing utility sink in laundry room 71Whaler Plumbing 9 11-24-2011 10:33 AM
Suggestions on correcting this Laundry room plumbing problem. theedudenator Plumbing 15 02-17-2010 08:49 PM
Basement Bath Sink / Laundry Vent Smell bestchoice Plumbing 1 02-08-2010 09:14 AM
Basement Reno - Laundry, Bathroom mostr Building & Construction 2 03-02-2009 09:50 PM
