Plumbing For Utility Sink In Garage - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-16-2012, 10:36 AM   #1
Rewards Points: 2,516
Plumbing for Utility Sink in Garage
I want to add a wash sink inside my garage. On the opposite side of the wall where I want to add the wash sink there is an inside bathroom sink. See two different diagrams below for existing setup. What I want to do will be in my next post. The diagrams are not to scale and some of the shown drain lines are not straight.
Plumbing for Utility Sink in Garage-exist-k.jpg   Plumbing for Utility Sink in Garage-exist-sketch.jpg
hammerlane is offline   Reply With Quote
Old 10-16-2012, 10:39 AM   #2
Would it be OK to just cut in a San-T at position "A" and use this to pick up the utility sink.
AAV's are allowed in my jurisdiction to vent it if needed??
Old 10-16-2012, 11:02 AM   #3
if you are talking about one of those laundry tub sinks, 18 inches is a little high for one of those. we always roughed those in at around 12-14 because they are so deep. what you propose would work.
Old 10-16-2012, 11:43 AM   #4
Thanks.
From the garage floor to the top of the bottom plate is just under 13 inches. So I could probably cut that San-T in so that the tap is at about 15"
In your opinion, is there a need for an AAV? Or could I just have the vent for the bath sink vent the utility sink?
Old 10-16-2012, 03:40 PM   #5
With the use of an AAv for venting, This is how the install would look after the San-T at position "A". Refer to diagram in post #2.
Old 10-17-2012, 06:11 PM   #6
Had someone say to take the "PROPOSED" drawing in post #2 and modify it to this:
Said to take San-T at position "A", turn it to the left, use a Wye on its back(fitting "F") with a Street-90(fitting "G"). The Street-90 would pick up the slop sink.
The Following User Says Thank You to hammerlane For This Useful Post:
Alan (10-17-2012)
Old 10-17-2012, 08:29 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I like your modification. That would be legal here.
Nice work.
Journeyman Plumber
Old 10-17-2012, 08:59 PM   #8
Would not this configuration work with the use of an AAV after the stub out from
San-T fitting "A"???
Old 10-17-2012, 09:23 PM   #9
Doing it myself
Alan's Avatar
It would. I prefer conventional venting methods, however.
Journeyman Plumber
Old 10-17-2012, 09:40 PM   #10
I understand. Thanks.
kitchen revamped, help with sink drain plumbing rfire15 Plumbing 6 09-29-2011 08:45 PM
New DIYer - bathroom sink plumbing help AdeAhmed Plumbing 7 09-21-2011 09:18 PM
Bathroom remodel, sink plumbing dschmid Plumbing 3 02-03-2011 08:32 PM
Plumbing pedestal sink G Archer Plumbing 1 01-30-2011 03:34 PM
Pedestal Sink Plumbing Options gth1 Plumbing 5 01-02-2011 03:02 PM
