Old 10-14-2005, 07:36 AM   #1
Plumbing type and size
Can anyone tell me what kind of pipe is best for residential plumbing- my plumber is using plastic not copper and the pipes to the sinks and tubs are only 1/2 inch - is that kind of small?- house is 4500 sq ft if it matters.:confused:
We are worried about water pressure and taking too long to fill the garden tub.
marlenecapps@cox.net is offline   Reply With Quote
Old 10-14-2005, 11:03 AM   #2
renovations
1/2 " is standard in residential, and the pipe he's using is probably pex (crimped joints?) which is becoming standard.
Bonus is offline   Reply With Quote
Old 10-14-2005, 12:42 PM   #3
Contractor
I'm staying with copper pipe. I know too much about plastics and remember the PBT debacle too well to endorse PET until it has been in use for 50 yrs.
As Bonus said, 1/2" is standard and should fill the tub as fast as it's ever been filled. If you are using standard bath fixtures, all is well. If you are installing a Jacuzzi tub for 4 or a shower with 4 or more heads, you may want to rethink the plumbing to that bath.
The larger the house, the more critical plumbing becomes if you are using a standard water heater configuration.
Teetorbilt is offline   Reply With Quote
How to Size a Furnace super_man4471 HVAC 18 03-25-2010 10:12 AM
What size should cold air return grille be? AllGoNoShow HVAC 1 02-27-2007 04:48 PM
Plumbing questions - finishing upstairs bonus room luner99 Building & Construction 1 02-07-2007 08:12 PM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 01:38 PM
What size nailer to use for Soffit Replacement Mach5 Roofing 2 01-28-2006 12:24 PM
