Thanks everyone.
I've checked around a bit and it seems the expected install method (in Ontario) is indeed above the trap. I don't know if it's required this way by code, but I found an online code cheat/study page that describes this.
Zosoplumber: The code also says 1 1/2 pipe is the requirement. I expect that 2" pipe would be much better, but I don't have an option there, as I'm plumbing into the vertical-portion of a circuit-vent, which is only 1 1/2". So, I'd have to dig up the entire floor and re-run the entire drain to get to 2" pipe or larger.
Instead, I figure I'll install the standpipe so that the top of the standpipe is higher than the laundry tub it's connected to (above the flood rim, I think is the code-way of saying this?) which should help ensure that any backup ends up in the sink rather than coming out of the standpipe. I'll also use one of those rubber gaskets to connect the washer outlet to the standpipe.
Finally, I'll take care to make sure the washing machine drain water doesn't have to do much directional change, etc.. I realize this isn't ideal (the 2" drain would be better) but I'm hoping these steps will still give me good performance (no overflows).
Any comments here? Any other steps I can take?
