Plumbing Through A Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2010, 01:28 PM   #1
Plumbing through a slab
OK, so I did something stupid, and now I need advice on the best way to fix it!
Our house is on a slab, and I ran new water and drain lines for a new kitchen island. This of course required openning the slab which I've since re-poured. What I forgot to do was wrap the waterlines before pouring the concrete... which means I'm worried about them eventually developing leaks as they rub against the concrete.
It's 1/2 copper, and only going to a single sink... so I'm not concerned about losing a bit of inner diameter on the pipe. Is there some sort of inner sleeve that I could run and bound to the inside of the pipe? I'm just looking for something that I can do now before I have issues, and avoid having to re-open the slab.
Thank you for any suggestions.
phxhome is offline   Reply With Quote
Old 08-30-2010, 03:46 PM   #2
Rewards Points: 730
My suggestion would be to get a good concrete drill bit and drill a bunch of holes around the pipe and then take out just enough material to where you can sleeve the pipes and then fill the holes back with hydraulic cement. This would be short work with a good hammer drill and if you don't have one, I'd bet you could rent one for under $50. Of course be very carefull not to drill into your line. Another option if you have an angle grinder is to get a diamond blade and cut a small section out. I'd be willing to bet with either method, you could be start to finish in under 2hrs and it'd be fixed right.
Master Brian is offline   Reply With Quote
Old 08-30-2010, 05:12 PM   #3
Thank you Brian, that does sound like a relatively painless and "correct" solution. I guess I know what I'm doing this weekend.
Old 08-30-2010, 07:44 PM   #4
Rewards Points: 730
Hope it works well. If you use the diamond blade, just be sure to cover stuff up those things create a lot of dust when done dry, but it'll eat through the concrete like butter.
Come to think of it, you can also get the diamond blades for your skill saw as well.
Good luck!
Old 08-31-2010, 10:19 AM   #5
I'll try the skillsaw... "like butter" has such an appeal!
Old 08-31-2010, 10:32 AM   #6
Rewards Points: 730
Just be sure to cover anything important up and wear a mask as it will get dusty!! I haven't done it much, but my neighbor is a mason and I borrowed his to cut some concrete block in my basement. I hate it, but it gets the job done!!!
Old 08-31-2010, 07:45 PM   #7
have someone stand next to you with a squirt bottle w/ water in it. Light misting will really help with the dust. Wear a mask while doing it too
the_man is offline   Reply With Quote
Old 09-01-2010, 11:50 AM   #8
be more careful when you do things like this
los angeles plumber
vegaschk is offline   Reply With Quote
Under slab plumbing SS396 Plumbing 1 11-13-2009 05:27 AM
Shower Pan and concrete slab plumbing LTempleton Kitchen & Bath Remodeling 2 08-08-2009 12:47 PM
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 12:41 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 07:37 PM
Ant's through slab plumbing aace Pest Control 4 02-13-2008 03:48 PM
