Old 09-27-2010, 06:08 PM   #1
Plumbing submersible well pump
I am installing a Gould 1.5 HP submersible motor and pump assembly to upgrade my irrigation system and the pump is stainless steel with the discharge end of the pump bneing 1-1/4" Female NPT. Is it ok to use a brass 1-1/4" male connector with a barbed end to tie into the poly pipe from the pump or should I use a schedule 80 PVC fitting or try to find a stainless steel fitting? I don't know if electrolysis occurs under water or not between the different metals. The Sch 80 fitting looks to be strong enough to hold the 100' of 1-1/4" poly pipe since I will be utilizing a safety rope to the top of the well seal cap from the pump. What are your thoughts?
cwalt43 is offline   Reply With Quote
Submersible pump plumbing cwalt43 Plumbing 0 09-15-2010 12:25 PM
submersible well pump . first start. ryanh Plumbing 11 07-12-2010 10:26 AM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 07:13 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
power to submersible well pump erlindbl Electrical 24 02-08-2009 10:17 PM
