Plumbing Single Handle Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2011, 12:06 PM   #1
Plumbing single handle shower
I'm going to be plumbing in a single handle shower/bath valve for my new bathroom. The kit I purchased has a valve with four 1/2" female outlets. I've got PEX to the bathtub, so for the inlets I'll be using female 1/2 to male PEX fittings. I plan on doing the same to connect the shower drop ear elbow.
I don't want to use PEX for the bathtub faucet... so what are my options here? I was planning on going with brass, but I couldn't get a nipple large enough to connect the valve to the elbow (I'm assuming I'll have the same trouble from the elbow to the faucet, as well). Is iron a reasonable option? I don't know anything about soldering, so I'd prefer not to go that route...
Thanks!
zrooster99 is offline   Reply With Quote
Old 02-26-2011, 07:05 AM   #2
Anyone with any input on this? Other than sweating in copper, what is the standard?
Old 02-26-2011, 07:17 AM   #3
Builder/Remodeler
ChrWright's Avatar
Galvanized steel nipples and fittings would work--but I wouldn't consider it ideal.
A professional plumber would likely use copper sweat connections for everything, and a pex adapter only on the hot and cold feeds.
ChrWright is offline   Reply With Quote
Old 02-26-2011, 08:42 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 684
Sweating is the way I'd do it. Get a couple feet of pipe, some fittings and practice, its not that bad.
Old 02-26-2011, 09:01 AM   #5
Thanks for the input... this morning I went by the local Do It Center, and got a couple brass nipples and a coupling... more expensive than I wanted, but it'll do the trick!
ChrWright... is there an issue with using PEX to connect the valve a drop ear elbow for the shower?
Old 02-26-2011, 09:45 AM   #6
Builder/Remodeler
ChrWright's Avatar
No, as long as you plug the drop elbow (typically done with a nipple and cap, which are left in place until trim-out) and turn the valve on to test for leaks before you close up the wall.
shower plumbing fix? With pics!! tomknox Plumbing 4 10-21-2010 08:22 AM
Shower Plumbing Help (Shower Arm) sjharner Plumbing 1 05-12-2010 10:18 PM
Access Panel or Door for Shower Plumbing Any pics? twilightcall Plumbing 4 12-22-2009 05:53 AM
Trouble replacing 2 handle shower levers matt7125 Kitchen & Bath Remodeling 2 12-02-2009 07:55 AM
Low Water Pressure Delta Single Handle Shower Model 602 rckeagle Plumbing 2 07-24-2009 02:11 PM
