Plumbing Shutoff For Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2014, 01:48 PM   #1
Plumbing shutoff for water heater
I have a two water heater setup in my home and I have determined I really don't have a current need for two. I would like to shut one of them off for the time being, but I haven't had a lot of interaction with water heaters in the past, so I want to make sure I do it right.
I attached a pic of my setup. They are piped parallel with one shutoff for cold supply going in. I am assuming I can just pipe in another shutoff after the tee on the cold supply to the water heater I want to turn off. Will this be sufficient? Do I need to do anything else on the hot supply side?
Another thought is just unhooking the cold and hot supply from the tank I'm not using and put some kind of plug in the connector. Is this possible?
I am thinking I should probably turn off the water heater without the expansion tank (the one on the left), correct?
Also, should I do anything to the one that I am turning off? I was thinking I would empty it and turn off the gas supply to it. Should I do anything else?
Thanks a lot for any help.
bartleby is offline   Reply With Quote
Old 01-18-2014, 01:51 PM   #2
Old 01-18-2014, 06:00 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is this going to be a permanent situation or do you plan on hooking it back up to where you have two water heaters at some point?
Journeyman Plumber
Old 01-18-2014, 06:39 PM   #4
An old Tradesmen
Rewards Points: 7,816
I'd re-pipe them in series. And just leave the leaving water heater on. that way the first water heater acts as a tempering tank.
If you want to totally disconnect the unused one. yes, you must use the one with the expansion tank.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (01-20-2014), plummen (01-20-2014)
Old 01-18-2014, 06:57 PM   #5
It is going to be a temporary adjustment. My kids are all still young, so the need for hot water to supply consecutive showers isn't there. I will probably hook it back up within 5 years or so.
Old 01-18-2014, 08:32 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 996
letting a water heater sit idle for long periods of time is not recommendable especially gas.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following 2 Users Say Thank You to Javiles For This Useful Post:
Old 01-19-2014, 10:58 AM   #7
Thanks for all the input. Here is my thought process, for those with more experience please enlighten me if I am off.
My purpose in getting rid of one of my wh is (obviously) to save energy costs. My thought is if my gas bill goes down $30 or so per month and I do this for 5 years my savings will be about $1800 over 5 years. What I am now trying to understand is - with two water heaters do they "load balance" the cost? In other words will my one water heater have to work twice as much if I pull one of them out of use? If my savings will be closer to maybe $10 a month it doesn't seem like it will be worth the hassle.
Old 01-19-2014, 12:06 PM   #8
An old Tradesmen
10 bucks is about what you will probably save. The one water heater will now run twice as long as the 2 together did when you use hot water. The only savings you will get are from less standby loss.
bartleby (01-20-2014), ben's plumbing (01-20-2014)
Old 01-20-2014, 05:20 AM   #9
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id run them in series as suggested previously.
Then just turn down the temp on first heater and use it as a preheater to help with recovery time on second unit.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-20-2014, 05:12 PM   #10
I was pretty set on taking one out for a while, but with the minimal savings (thanks beenthere) I am going to bag that idea. I hadn't taken putting them in a series as a possibility, but now I am more interested. Back to the purpose of what I'm doing, would I really see any savings by putting them in series vs parallel?
Old 01-20-2014, 06:11 PM   #11
plummen's Avatar
It would be easier to regulate the temp on the first one if they were in series, that save you money on gas.
It would also give you a decent supply of hot water, and you could turn it up or down depending on amount of hot water needed.
The Following 2 Users Say Thank You to plummen For This Useful Post:
Alan (01-20-2014), jmon (01-20-2014)
Old 01-20-2014, 07:14 PM   #12
An old Tradesmen
In series, you have the choice of either shutting the first one off(burner) completely, or setting it to vacation.
Shut off, it acts as a preheat tank slowly absorbing heat from the basement. Saves a buck or so a month more then just removing it, depending on water use.
Set on vacation. It acts as a pre heater/warmer, and the second water heater doesn't have to raise the temp of water as much on long water draws, so you still get an increase in hot water volume over only having 1 water heater. And down the road, when you have a higher hot water demand, you just turn the thermostat up to a higher temp.
The Following 3 Users Say Thank You to beenthere For This Useful Post:
Alan (01-20-2014), jmon (01-20-2014), plummen (01-20-2014)
Tags
water heater
Turning off hot water to fix 1/2 inch CPVC pipe in crawl space steve3847 Plumbing 21 12-20-2012 01:53 AM
Two plumbing questions: Water heater drain and expansion tank. TexasPenguin Plumbing 10 10-30-2012 01:35 PM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
