-   -   Plumbing for shower and steam generator (http://www.diychatroom.com/f7/plumbing-shower-steam-generator-134358/)
Smitny22 02-20-2012 10:41 AM
3 Attachment(s)
I am redoing my master bath to include a steam shower. I have come up with the plumbing setup in these pictures to accomodate the shower drain, as well as the drain from the steam generator. I was hoping that I could get some opinions on it before I open the cement. Does this setup look okay, and if not, what should be changed? I am in Colorado.
Attachment 46262
This is the drain for the shower, 2" ABS. Even though the picture doesn't show it very well, there is a good slope from the trap down to the drain pipe exiting into the floor.
Attachment 46263
Rotating around counterclockwise, this is a view where the line rises into the wall, branches off for the steam generator line and p-trap in the background. You are looking through a hole into my closet where the steam generator will be located. The pipe sticking up in the foreground will be the vent, which will 90 left through the stud (after I reroute the copper line) and then 90 up to join the existing vent that you can see near the top left of the picture.
Attachment 46264
This is a shot from inside the closet. The steam generator will be elevated more so there is sufficient slope down to the 1 1/2" drain pipe. Room is tight in here so I crammed everything together. There will be two 1/2" copper lines running to this drain, one from the auto-flush line, and the other from the drain pan line that you can see at the end of the pan. The copper will hover slightly above the abs pipe. I also installed a cleanout just above the wye for the steam drain.
Any and all help or criticism is appreciated. Thanks. -Leland
TarheelTerp 02-20-2012 02:42 PM
1 Attachment(s)
I bet if you thought about it some...
you could get even more fittings into that shower trap set up.
TheEplumber 02-20-2012 03:07 PM
199 Attachment(s)
The vent should be above the center line of the trap arm for the shower drain.
Smitny22 02-20-2012 04:25 PM
The vent should be above the center line of the trap arm for the shower drain. Today 07:42 PM
Yes, there will definitely be a more positive slope from the drain up to where it makes the rise through the footer at the wall. I assume that's what you mean, right? I got in a hurry to take the picture before I added the support for that end. Thanks for the help. Anything else?
M Engineer 02-20-2012 04:34 PM
I am not a plumber but where is the vent for the shower?
Smitny22 02-20-2012 04:36 PM
Reference picture number 2 above, it is the pipe that extends from right to left and then up through the wall. It is not yet connected to the existing vent pipe because I have to pass it through the stud and there is currently a copper line in the way.
M Engineer 02-20-2012 05:16 PM
Sorry. I thought that was a drain for other fixtures.
TheEplumber 02-20-2012 05:16 PM
199 Attachment(s)
No, thats not what I meant, you shouldn't have the vent horizontal to begin with, and if you do it it should come of the branch of the wye so it can be rolled above the center line of the drain.
Smitny22 02-20-2012 05:57 PM
Okay, I get what you're saying now. The person who proposed this particular setup had said that it was wet venting. And another person was the one who suggested all the extra fittings to make the 180 turn less convoluted. Can't win sometimes.
I am going to try one more configuration on this making sure to roll the wye and use the branch like you suggested. Now that I have drilled the extra hole in the footer, I will just vent each drain separately. I will try to get another picture up tonight before I go out of town. Thanks again.
TheEplumber 02-20-2012 06:02 PM
199 Attachment(s)
How hot is the condensate from the steam generator?
Smitny22 02-20-2012 06:19 PM
The auto-flush valve waits at least two hours after each steam for the water to cool and then opens to empty the tank. The worst case scenario mentioned by the rep at Mr. Steam is for a power outage during steam production which could then dump water at temps at or above boiling into the drain line. I'm guessing in that scenario I wouldn't necessarily want to have a wet vent, huh?
