Old 03-09-2009, 07:21 PM   #1
Default Plumbing in the shower head
I am installing a tiled shower with a rain shower head. I have a Moen pressure/temperature balancing valve with pex fitting, which has two outlets. One for a tub and one for the shower. Since I do not need the tub outlet can I join the two outlets to go to the shower head rather then capping the tub outlet? I notice the the outlet for the shower head is a smaller diameter then the tub and I want to make sure I have enough water going to the shower so that is does not dribble out. I would be going up to the shower with 1/2 pex pipe and it is 1/2 pex pipe going into the valve on the hot and cold. We live in the country so we use a pressure tank.So the question is: can I join the two outlets to go to the shower without something going wrong?
obeans is offline   Reply With Quote
Old 03-09-2009, 07:47 PM   #2
Man of many hats
wrangler's Avatar
Definitely NOT. That valve requires back pressure from the tub spout being closed to force the water to the sh0wer head, so if you have both going to the SH, the tub spout of course can not ever send water to the top side (shower head side) of the valve. You will gain nothing, but a little more added expense at best. One thing I have 'heard' of people doing, though I am quite sure not legal in many areas of the country, is to remove the water flow restrictor (often a little plastic piece in the shower head just under the screen) to allow a heavier flow. I have heard that people that do do this must also make sure that all pieces of the restrictor are removed or shaken from the shower head to ensure that the water is not still restricted by debris. Sometimes, this would also require a slightly thicker washer if the restrictor is attached to one of the washers, though, I would really not know as I would never try to circumvent the government from trying to legislate how i TAKE MY SHOWER. If not for them I might drive 200mph, never wear a seat belt or helmet and stand on the top rung of a ladder!
Man of many hats
wrangler is offline   Reply With Quote
Old 03-10-2009, 08:50 AM   #3
plumbing contractor
PLUMBINGITALL's Avatar
It will work but it is pointless because you are not going to get any more water. I have done something like this were i used the tub outlet to go to a hand held shower.
PLUMBINGITALL is offline   Reply With Quote
Old 03-11-2009, 05:08 PM   #4
Thank you for your input.
Tags
shower, shower only rough valve
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip we'll be turning off the water. Now some tubs have an access panel or you can actually reach into the wall and they'll be a shut off valve located in the wall that will just shut off the water... Read More »
Hi I am Adolph Ramirez from Tampa, Florida and on behalf of Expert Village today I will show you how to clean a shower head. The next thing you want to do is disassemble the flow restrictor and remove the little o ring. I am going to dunk it in a little... Read More »
Faucets should accentuate the overall appearance of your bathroom. You can choose from a large selection available at hardware stores, home centers, bath remodeling showrooms and plumbing wholesalers. You can also shop online. Whether you are replacing... Read More »
Hey everybody, Don Golden for Expert Village and we are back in the shower here and what I want to do is show you how the shower works and the valve that we are going to have to take apart here to stop this nasty leak. Now if you look at the way this is... Read More »
Hi, I'm Adolph Ramirez from Tampa, Florida and on behalf of Expert Village, today I'll show you how to clean a shower head. If the shower head in question happens to be a recently built apartment or house, mineral build-up may not be the problem at all... Read More »
Shower Head Breaking Off mbarnes Plumbing 3 01-11-2009 08:38 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 01:23 PM
very low shower head flow rickard681 Plumbing 8 10-08-2008 08:43 AM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 07:49 PM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 11:19 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
