Plumbing For Shower And Commode In Upstairs 2 X 6 Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2012, 03:04 AM   #1
plumbing for shower and commode in upstairs 2 x 6 floor
The tornado hit my house and the 2nd level was reconstructed on a 2 x 6 floor. How can I plumb in the traps for the shower and commode for the upstairs bathroom?
Cathy OLINGER is offline   Reply With Quote
Old 12-20-2012, 05:46 AM   #2
DIY staff
Rewards Points: 7,174
Cathy---you need to give us some more details and a correct size---2x6 is too small for a shower and toilet---
photos help--a plan is also good in new construction---do you need to simply install the P-traps? or do you need to rough in the entire plumbing?
Old 12-20-2012, 07:46 AM   #3
I think she means 2x6 floor joists were used maybe?
josephvelder is offline   Reply With Quote
Old 12-20-2012, 08:29 AM   #4
DIY staff
Ah,yes---floor joists---I never saw a 2x6 floor joist so that did not sink in---around here we use bigger ones----good catch---
Old 12-20-2012, 08:37 AM   #5
Rewards Points: 3,130
Using 2x6 floor joists seems a bit anemic unless the span is really short. In my log house, the joists are 2x12 at 16" oc. In high traffic areas, they're doubled up. In the kitchen, they're 12" oc. Trust me, my floor doesn't bounce.
The Following User Says Thank You to md2lgyk For This Useful Post:
oh'mike (12-20-2012)
Old 12-20-2012, 08:39 AM   #6
Rewards Points: 13,446
I'd be very, very concerned with just 2 X 6's for floor joist!
Old 12-20-2012, 08:47 AM   #7
DIY staff
What will be left when the 3" drain goes through it?
Old 12-20-2012, 10:28 AM   #8
Special User
Rewards Points: 1,230
http://www.metwood.com/products/reinforcer
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-20-2012, 04:16 PM   #9
Roofmaster
Rewards Points: 2,172
What distance OC and Span are you carrying? Who designed your new upper floor???
Old 12-20-2012, 05:34 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 546
Shower trap will not be concealed in a 2x6 floor and a toilet does not need a trap under it- its in the toilet
Old 12-20-2012, 06:10 PM   #11
Why was the floor framed with 2x6's?!?
If that meets code (and I'd be surprised if it did), you have a couple of options:
1) Change it from a shower to a tub. A shower requires a 2" drain while a tub only needs an 1 1/2" drain - assuming you're within so many feet between the trap and the vent (in my state, that's 5 feet, but check your local codes). An 1 1/2" ptrap will fit within 2 x 6 framing.
2) If you have the height below, drop the ceiling to give you a couple more inches. Strapping nailed to the bottoms of those joists will give you an extra 3/4" to play with - maybe double, or triple strap it if you have to.
Hopefully, the toilet is close enough to a partition below that you don't have to run very far. Within a 2x6 floor structure, the closet bend will already be at, or below the bottom of the joist even when it's pushed up as high as possible. Then the horizontal drain needs to have 1/4" pitch until it drops to vertical. That strapping (mentioned above) will get you (hopefully) a maximum 3 foot run.
And finally, you certainly can't drill a 3 5/8" (OD) hole through a 2x6, so unless the toilet drain runs straight down between two joists and immediately down a "wet wall", you won't be able to do it.
Ishmael is offline   Reply With Quote
Old 12-20-2012, 08:13 PM   #12
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I know they make bathtubs in "Above floor rough-in" configuration, perhaps they make a shower in a similar style so that most of your trap arm and p-trap will be above the subfloor, resulting in a step up into the shower.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
joecaption (12-20-2012)
Old 12-21-2012, 09:12 AM   #13
Rewards Points: 262
Entire cities were built like that up here, all 2x6 ceiling bungalows. Being low-ceiling upstairs means showers are nearly out of the question unless you put it right in the middle of the wall or build out a dormer. The spans are short so putting a toilet or sink near a bearing wall below is quite common. What I did in mine was ran the drains parallel between the joists, then dropped down to the first floor to a common line, then soffit-ed over it to conceal it. Never would I attempt to put the weight of a tub on it though.
moneymgmt is offline   Reply With Quote
leveling commode after repairing bathroom floor? albertabrown Kitchen & Bath Remodeling 2 10-24-2012 04:59 PM
Commode Flange Not Flush With Floor vabear Plumbing 6 02-07-2012 09:18 AM
Wife's Plumbing dwayne423 Plumbing 1 01-29-2010 11:08 PM
