Old 08-06-2010, 01:15 PM   #1
Electrician
Proby's Avatar
Plumbing a shower.
I am changing my bathtub into a shower. The plumbing in the wall is copper and shutoffs were added about 7 or 8 years ago. Instead of getting a torch and sweating copper in for the new controls and shower head, could I just use Gatorbite fittings and Pex? Would I be able to adapt the Pex and Gatorbite connectors to the shower head and the controls, or would I need one of those expensive crimpers?
Thanks!
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-06-2010, 03:05 PM   #2
WDR
Plumbing a shower.
if the shower parts have threaded fittings you could probobly connect the pex to them them with threaded x pipe gatorbites, if they have sweat fittings you would have to use all copper pipe or sweat short pieces of copper pipe into the shower parts and then use gatorbites and pex
WDR is offline   Reply With Quote
The Following User Says Thank You to WDR For This Useful Post:
Proby (08-06-2010)
Old 08-06-2010, 03:24 PM   #3
Electrician
Proby's Avatar
Plumbing a shower.
Ok. So if I am going to have to sweat short pieces on it would probably be best to just sweat it all, correct? I was just looking for an easier way out
Old 08-06-2010, 03:26 PM   #4
WDR
Plumbing a shower.
Yes if its not threaded I would just sweat it all in.
Old 08-08-2010, 09:48 AM   #5
Owner
Plumbing a shower.
PEX crimpers don't have to be expensive. They can range from $30-$150+. Obviously you won't get the best quality for 30 bucks, but for the amount you'll be using them probably not a big deal.
If your shower valve is threaded, you can use threaded by barbed brass fittings in that, but would still need to sweat adapters on the supply lines coming up in the wall. I wouldn't use Sharkbite fittings unless that's your only option (i.e., don't know how to solder).
If you need to sweat your shower valve, it's typically easiest to do it while it's out of the shower. If you're not experienced with soldering, take the cartridge out first to avoid melting/damage.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Find us on Facebook
LateralConcepts is offline   Reply With Quote
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Plumbing in the shower head obeans Plumbing 3 03-11-2009 04:08 PM
which way to route shower plumbing? everyman Plumbing 11 03-04-2009 09:10 AM
Shower Plumbing Ron Plumbing 1 08-15-2007 12:38 PM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 09:26 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
