Plumbing A Sewage Ejector Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2011, 09:18 AM   #1
Plumbing a sewage ejector pump
When I had a new garage built I anticipated needing a sewer line in the garage and also putting a bathroom in my basement so I had the builders install a sewage ejector pump. Now that I am preparing to design my basement bathroom I am concerned about the way the pump is plumbed in. The pump has two holes in the top. The main sewer line extends via 2" pvc straight to the ceiling of the basement and tees. The sewer line continues over about two foot where it y's into the main sewer line with the washing machine's ejector pump. The pipe diameter here is 1.5" for a few feet.
Where the sewage ejectors main line tee's at the ceiling, the other part of the tee goes up a few inches, horizontal for a foot and then 90 degrees right back down into the other hole on top of the sewage ejector basin which I assume is the vent hole.
Is this an acceptable way to plumb this device? Also could I remove the washing machine pump from the line and just have the washing machine dump into the waste line that leads to the sewage ejector pump?
noviceguy is offline   Reply With Quote
Old 03-11-2011, 09:31 AM   #2
Love for Construction
<*(((><'s Avatar
Here is a diagram detailing macerating pump install.
-luke-
<*(((>< is offline   Reply With Quote
Old 03-11-2011, 09:36 AM   #3
Okay, on that picture visualize where the cleanout is. On mine, that extends right over to and cuts off the vent line and forms a loop. These guys were licensed plumbers and promised me it was up and ready to go, just needs to be plugged in. Were they lying to me?
Old 03-11-2011, 09:59 AM   #4
From your description, your instalation is NOT correct. The vent must extend to the roof. A loop like you describe does not allow for sewage gasses to be removed from the system and also no return air for the pump causing a vacum when the pump is activated.
bhennon is offline   Reply With Quote
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 08:55 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Sewage odor in basement when plumbing used Stehvi Plumbing 6 01-04-2007 08:10 AM
