Old 01-15-2012, 02:47 PM   #1
Plumbing runs on basement outside wall
I want to run hot and cold PEX lines down a 2x4(wood) batt insulated "outside" basement wall to where my builder has roughed in a sink drain. I know that running plumbing in exterior walls above grade is usually not allowed but does this apply to the basement? If I'm allowed, what precautions do I need to take?
I live in a winter climate that gets very warm in the summer to sometimes arctic cold in the winter.
n0c7 is offline   Reply With Quote
Old 01-15-2012, 03:05 PM   #2
Very bad idea, They should be if at all possible run down the center of the crawlspace and in your area I'd also insulate them with foam tubes.
Old 01-15-2012, 03:18 PM   #3
Sorry when I said outside wall I didn't actually mean outside. It's on the interior of the house foundation walls.
Old 01-15-2012, 03:27 PM   #4
Where are yu most likly to get air leaks in a crawl space?
Any cracks, gaps under the foundation plate, any vents. Moving cold air is what's going to freeze those pipes.
Old 01-15-2012, 04:13 PM   #5
call me E
TheEplumber's Avatar
When you drop into the wall, stay to the warm side of the insulation- against the drywall. Be sure the rim joist is insulated well.
Old 01-15-2012, 06:04 PM   #6
Here's a pic of what I'm working with:
Should the pipes be behind the vapor barrier or in front?
Old 01-15-2012, 06:25 PM   #7
In front
Old 01-15-2012, 06:42 PM   #8
Originally Posted by joecaption
In front
Now that you've seen a picture - were we talking about two different scenarios?
Old 01-19-2012, 06:22 PM   #9
Local authority says in front of the vapor barrier but behind the drywall. Not sure how you clamp it down like this but hey.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Basement Wall to Floor Spacer jimmyfloyd Building & Construction 4 05-27-2011 08:43 AM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
Basement knee wall question vugger Building & Construction 2 01-05-2008 10:02 PM
